Previous Thread This topic has been viewed 3952 times and has 2 replies Next Thread
xtal_01
gray "block" when I drop in items .....
Hello,
I am having a funny problem.
Let me give two examples:
1) I draw a roof and export it as an OBJ file. I bring it in and place it on the house. In the 3D view the roof looks great but I see a gray block at the end. It is the size of the end view of the roof. I can not see through this block.
2) I draw a triangle window. Again, I export it as an OBJ file. I import it ( as furniture ) and place it into a wall. Although I see the window as a triangle, the "hole" for the block is a square. I see a chunk of wall missing.
I assume (maybe wrongly) that this is one in the same problem?
The window is annoying but not really a problem. The gray block at the end of the roof is a real problem. I can not get a good picture of the house with a large gray block at the end of each roof.
Thanks ..... Mike
[Jul 4, 2012, 4:01:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: gray "block" when I drop in items .....
I guess this is due to the ground part that is generated around the walls as soon as there's a wall in the home you export to OBJ. In his guide, Hans suggests that you use also the Copy as new furniture plug-in. Personally, I export a flat box or for more complex shapes, a floor at an upper level (to ensure I'll get both faces), and orientate it degree by degree at the second importation step.
The hole made by a window is always rectangle in the current version. You will have to add some other shapes to complete the hole.
[Jul 4, 2012, 2:49:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
xtal_01
Awesome!
I will give this a try.
This program has been a life saver!
I am a mechanical designer and with the exception of some Solid Works projects I did for a group doing CNC 3 axis machining, my work is always done on AutoCad in 2D.
My partner (could not get married or she would loose her health insurance) and I just bought a lot and are planning to break ground with in the next month.
She is paralyzed from the shoulders down as the result of a diving accident then she was 12 ( she is 32 now). This will be her first house.
The program has made it easy to discuss design aspects with her ( clearances, a roll in show, counters that are accessible, ...).
I even used the movie feature for the first time (posted it on You Tube) to show a walk through of the house to family (who live 800 miles away), friends and even the builder (it even made it much easier to describe the odd features I needed to him).
http://www.youtube.com/watch?v=QUniZrBbGFM
It is not "great" but it did do the job. Once we get all the quotes in and the recommended changes from the builders, I will rework the model to be "more correct". There is a lot of details I "faked" just to get the model out in a hurry ( and a lot of details I left out).
If you (or anyone) gets a chance to watch it and sees and obvious error I am making using this program, please let me know! I am "learning on the fly".
Thanks so much .... Mike
[email protected]
[Jul 4, 2012, 3:50:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
