Canada
Dimensions and walls drawing
Newbie here... I am drawing walls, default thickness. I measured the real room INTERNAL dimensions, but as far as I understand when drawing a wall the dimension refers to the CENTER of it, so how to draw walls in such a way that the resulting internal dimensions correspond to the real ones ? Hope I've been clear enough. Thanks
www.stevegalante.com
Re: Dimensions and walls drawing
Your observation is right: walls are measured from their middle. As soon as you allow the user to draw more than one room in the plan, it would be difficult to measure an other way. But if you want to work with the dimensions of the room, you can draw the room first with the Room creation tool then switch to the Wall creation tool and double-click in the room to create walls around it.
