Total posts in this thread: 4
Previous Thread This topic has been viewed 2829 times and has 3 replies Next Thread
vkaci
Changing shortcuts
Does anybody knows, how can I change the shorcuts?
It sounds very good that the selection shortcuts ends with the first letter of functions like ctrl+shift+w for wall and r for room, but in this case both hands needed to press it, which is wery unconfortable because I need to release the mouse. So I would like to change some, but I do not know how.
Thanks for the help.
[May 29, 2012, 10:46:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Changing shortcuts
Unless you're a programmer able to update the program, it's not possible at this time. There will be probably a pane in preferences able to configure shortcuts.
[May 29, 2012, 11:44:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
vkaci
Thanks,
I have already downloaded the source and I tryed to find the relevant code but it is so big and I only exeperince width Java is the android ecosystem...
[May 29, 2012, 5:57:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's not in Java code, but in the src/com/eteks/sweethome3d/swing/package.properties resources file. Simply change the values of the keys named AcceleratorKey.
Good luck! smile
[May 29, 2012, 7:30:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
