Suggestion #7: Support for drawing command lines
Problem description: -------------------- - Sometimes, you want to draw a very complex figure or to put an object on certain place that if you would use some command lines instead of using mouse the task become easier.
Suggestion: ----------- - Add that feature.
- E.g. wall name hexstar wall hextar add point 287,000 wall hextar add point 250, 433 wall hextar add point 144, 250 wall hextar add point 000, 500 wall hextar add point -144, 250 wall hextar add point -250, 433 wall hextar add point -287, 000 wall hextar add point -250,-433 wall hextar add point -144,-250 wall hextar add point 000,-500 wall hextar add point 144,-250 wall hextar add point 250,-433 wall hextar add point 287,000 wall hextar pencil height 250 wall hextar pencil color #0000FF #FF0000 wall hextar pencil weight 15 wall hextar drawwall wall hextar drawarea
Visit my website (http://kokbira.c1.biz/)
Re: Suggestion #7: Support for drawing command lines
I really believe this kind of tool wouldn't be expected by the audience of this program. But this should be easily achievable with a plug-in since each line should match a Java call.
By the way, did you see that walls, rooms and dimensions coordinates and length can already be entered with the keyboard by pressing the <enter> key at creation time?
