Previous Thread This topic has been viewed 4889 times and has 2 replies Next Thread
danielfranklinr
Venezuela
java.lang.NoClassDefFoundError: javax/media/opengl/GLCapabilitiesChooser
Hello everyone.
I just downloaded SweetHome 3d v3.4 src and followed the instructions given in the readme file to install it on a OS x 10.7.2.
The project was succesfully imported into eclipse and the VM argument -Djava.ext.dirs=lib:lib/macosx was included to run the project as a Java Application (SweetHome3d.java) and a Java Applet (SweetHome3dViewer.java)
The Java Application runs just fine, but when i start the Applet it gives me the following stack trace:
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at javax.media.j3d.Pipeline$1.run(Pipeline.java:162)
at java.security.AccessController.doPrivileged(Native Method)
at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:157)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:965)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299)
at javax.media.j3d.GraphicsConfigTemplate3D.getBestConfiguration(GraphicsConfigTemplate3D.java:321)
at java.awt.GraphicsDevice.getBestConfiguration(GraphicsDevice.java:159)
at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:65)
at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:100)
at com.eteks.sweethome3d.applet.ViewerHelper.addComponent3DRenderingErrorObserver(ViewerHelper.java:372
at com.eteks.sweethome3d.applet.ViewerHelper.<init>(ViewerHelper.java:295)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at com.eteks.sweethome3d.applet.SweetHome3DViewer.createAppletApplication(SweetHome3DViewer.java:172)
at com.eteks.sweethome3d.applet.SweetHome3DViewer.init(SweetHome3DViewer.java:70)
at sun.applet.AppletPanel.run(AppletPanel.java:424)
at java.lang.Thread.run(Thread.java:680)
Caused by: java.lang.ClassNotFoundException: javax.media.opengl.GLCapabilitiesChooser
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
... 21 more
I went to the directory lib/macosx and the following files could be found:
gluegen-rt.jar
jogl.jar
libgluegen-rt.jnilib
libjogl_awt.jnilib
libjogl_cg.jnilib
libjogl.jnilib
I would like to know if I'm missing something here.
[Apr 5, 2012, 10:12:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: java.lang.NoClassDefFoundError: javax/media/opengl/GLCapabilitiesChooser
Since it's more realistic, I generally run the applet from a browser after running Ant applet target.
If you run it with appletviewer from Eclipse and didn't change the working directory set to classes folder by default, set VM arguments to
-Djava.ext.dirs=../lib:../lib/macosx
[Apr 6, 2012, 12:58:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
danielfranklinr
Venezuela
Thank you very much for your help.
I applied the change you mentioned, but it gave me an error opening the default sh3d file.
However, i used the Ant file and managed to run the applet in a browser like you said.
Thanks again.
[Apr 6, 2012, 9:55:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
