Total posts in this thread: 7
Previous Thread This topic has been viewed 16407 times and has 6 replies Next Thread
Cmbellomo
How do I calculate total floor area or room square footages?
Hello,
I am new to Sweet Home and am really happy with the features.
How do I calculate the square footage of the total floor plan or individual rooms so that it displays on my plan? I have searched for the answer but would appreciate any advice.
Thank you,
Chris
[Mar 9, 2012, 5:28:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How do I calculate total floor area or room square footages?
Click on the Create rooms tool and then double click on an exterior wall. This will create a room covering the whole home including the walls (it's not really a feature but you can use it in the current version 3.4). If you want something more accurate and you can program, you could create a plugin that will add the area of all the rooms.
[Mar 9, 2012, 6:36:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cmbellomo
Great, thank you. That works. But do you know if the area is calculated to the inside or outside of the perimeter walls and are there settings to adjust?
Has anyone created a plug-in to calculate area or sf for all rooms? Where could I check for developed plug-ins?
Thanks,
Chris
[Mar 12, 2012, 3:37:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Chris,
Areas are calculated from the centerline of walls, i.e. the lines determined by the X,Y coordinates.
A tutorial, including a list, for all available plug-ins can be found here.
[Mar 12, 2012, 4:55:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Moving the room area would have shown you that it includes the wall area (as said in my previous answer)
No, as far as I know.
[Mar 12, 2012, 5:39:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
matt01
If you draw a 10x10 box, it gives you 95 sf. Draw a line through it and it is less so it doesn't include interior walls. You have to take out for exterior walls too because it calculates it wrong. To find the exterior wall space of a 10x10 room, you must convert 3 in wall. divided by 12=.25 x 10=2.5, then times 4 is 10 sf. If it counted the exterior walls it would be 105 sf., not 95, is way off.
[Mar 20, 2016, 6:32:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Matt, the displayed area of a room object doesn't take into account the other objects at its border or upon it.
[Mar 22, 2016, 8:49:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
