Re: Sweet Home 3D 3.4
I have been using 3.4 for some time now on my 64bit Linux machine. When sending a saved file to a 32bit windows machine, that machine is not able to open the file. Is this a known bug?
I can make the windows machine read the saved file if I remove almost every object (just left a few doors in the drawing) so there seem to be related to the number/type of items in the drawing.
Re: Issue while transferring a .sh3d file
As SH3D files are fully compatible across operating systems, this has probably nothing to do with a memory problem or a Linux 64bits vs a a Windows 32 bits box, but it must be a issue related to the fact that the file wasn't transferred/copied correctly. The minimum check would to compare files size? Can you check they are the same?
Yes, I'm 100% sure they are the same.
I started by sending my orignal file and it could not be imported. I then created a dummy drawing without any objects (just walls) and it imported find. Then did I proceed by removing objects from my orginal file and saving as a new file, I repeated this until it imported ok. I had to remove every object except doors so the problem seem to be related to numer/type of objects....
How big is the file? Could you try to open it with Sweet Home 2D (requires you install Java first)? If it works correctly, that would mean that you have either a problem with the video card driver, or a problem of memory with Sweet Home 3D. If it fails also with Sweet Home 2D, send me the file. I'll have a look to it.
