Total posts in this thread: 5
Previous Thread This topic has been viewed 6148 times and has 4 replies Next Thread
kerfmas4
Background Image from command line
Hello all.
I would like to know if there is any way of execute a command to set the background image. Or command line.
I normally work with c# and before starting learning java, wanted to know if its possible to connect some simple functions like preferences,background image with c#.
Or if its possible to do programming a plugin.
The views preferences are easy to solve due to we can save a sh3d file and load through an external program renaming it.
So, what do you think will be more easy for me.
For the future I would like to integrate a little window sh3d viewer with move, zoom, just this. A form control would be perfect.
Thanks.
[Aug 26, 2011, 4:51:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kerfmas4
Re: Background Image from command line
OK. Finally I've decided to learn more about java. Now I can set a predefined Jpg as backgroundimage from the menu bar.
My new question is: How could I autoload this plugin function when the application starts without clicking on the menu item?
Thanks in advance.
[Aug 31, 2011, 3:36:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Welcome to Sweet Home 3D developer world. smile
If you want to program this only from the plugin you already created, you could set the background image of the current home in the getActions method you programmed. I guess this is not very clean, but it seems like a init method is missing in the Plugin class.
[Aug 31, 2011, 9:35:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kerfmas4
First of all, thanks a lot for your help. Now the code result that worked.
package com.eteks.test;
import java.net.URL;
import java.net.MalformedURLException;
import com.eteks.sweethome3d.plugin.Plugin;
import com.eteks.sweethome3d.plugin.PluginAction;
import com.eteks.sweethome3d.model.BackgroundImage;
import com.eteks.sweethome3d.model.Content;
import com.eteks.sweethome3d.tools.URLContent;
public class SetBackgroundPlugin extends Plugin {
public BackgroundImage ImagenFondo() throws MalformedURLException {
URL u = new URL( "file:/c:/4683.jpg");
Content content = new URLContent(u);
return new BackgroundImage(content, 2500, 0, 0, 700, 700, 0, 0);
public class SetBackgroundAction extends PluginAction {
public SetBackgroundAction() {
putPropertyValue(Property.NAME, "Compute volume");
putPropertyValue(Property.MENU, "Tools");
// Enables the action by default
setEnabled(true);
@Override public void execute() {
@Override
public PluginAction[] getActions() {
try {
getHome().setBackgroundImage(ImagenFondo());
} catch (MalformedURLException e) {
e.printStackTrace();
return new PluginAction [] {new SetBackgroundAction()};
Thanks again.
[Note from moderator: fixed code format]
[Edit 2 times, last edit by Puybaret at Aug 31, 2011, 11:37:32 PM]
[Aug 31, 2011, 11:19:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great you succeeded!
I fixed the code format otherwise it was unreadable.
[Aug 31, 2011, 11:39:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
