Hello to all, i am new in here and finally i found how to change the meters, but my problem now is bigger because i can't open the preferences tub to do the change. it shuts me out. I do not know why and only the preferences, everything else works just fine. Please please Help!
Re: I can't open preferences
Please read the FAQSweet Home 3D crashes when I want to edit preferences, print, create a photo or create a video. What can I do?
here you are the error message from javaws which is the same from web browser:
net.sourceforge.jnlp.LaunchException: Fatal: Read Error: Could not read or parse the JNLP file. at net.sourceforge.jnlp.Launcher.fromUrl(Launcher.java:491) at net.sourceforge.jnlp.Launcher.launch(Launcher.java:283) at net.sourceforge.jnlp.runtime.Boot.run(Boot.java:199) at net.sourceforge.jnlp.runtime.Boot.run(Boot.java:51) at java.security.AccessController.doPrivileged(Native Method) at net.sourceforge.jnlp.runtime.Boot.main(Boot.java:165) Caused by: java.io.IOException: www.sweethome3d.com at net.sourceforge.jnlp.JNLPFile.openURL(JNLPFile.java:255) at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:185) at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:162) at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:148) at net.sourceforge.jnlp.Launcher.fromUrl(Launcher.java:477) ... 5 more Caused by: java.io.IOException: www.sweethome3d.com at net.sourceforge.jnlp.JNLPFile.openURL(JNLPFile.java:255) at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:185) at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:162) at net.sourceforge.jnlp.JNLPFile.<init>(JNLPFile.java:148) at net.sourceforge.jnlp.Launcher.fromUrl(Launcher.java:477) at net.sourceforge.jnlp.Launcher.launch(Launcher.java:283) at net.sourceforge.jnlp.runtime.Boot.run(Boot.java:199) at net.sourceforge.jnlp.runtime.Boot.run(Boot.java:51) at java.security.AccessController.doPrivileged(Native Method) at net.sourceforge.jnlp.runtime.Boot.main(Boot.java:165)
Rosario,
On the Download page you can download installable versions for 32 bits and 64 bits versions of Linux. I use the 64 bits version, and it works fine with (L)Ubuntu 11.10.
If you have problems, try uninstalling ALL versions of Java on your computer (Sun Java and Iced Tea). Then install the downloaded version of SH3D.
[Edit 1 times,
last edit by hansmex at Jan 4, 2012, 4:18:15 PM]
