Total posts in this thread: 8
Previous Thread This topic has been viewed 7368 times and has 7 replies Next Thread
Cardinal
Can't find the plugin folder
Hello,
I'm using version 3.3 on Windows 7. I have looked for the following path :
C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\plugins
but under the Sweet Home 3D folder I have two other folders "work" and "recovery" along with "preferences.xml" and nothing for plugins.
Thanks for your help.
[Jul 27, 2011, 11:08:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can't find the plugin folder
plugins folder is created if needed when the user installs a plug-in (the same behavior applies to furniture, textures and languages folders where sh3f, sh3t and sh3l files are stored). You can create it yourself if you want to.
[Jul 27, 2011, 11:14:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cardinal
Thanks for your answer Puybaret.
I created the plugins folder and put a test plugin I wrote (a JAR file), but it's not read by SH3D when I run it. So I downloaded some plugin to double check and it worked. However, that plugin had a ".sh3p" extension. What's the diffrenece between a JAR plugin and a .sh3p plugin and how do I make one?
Thanks.
[Jul 27, 2011, 3:07:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cardinal
I also tried to test with the VolumePlugin from the tutorial to make sure I get everything right, but in the PluginAction.execute() method eclipse can not resolve the call to getHome(). And indeed I couldn't see where that method is declared?
Thanks in advance.
[Jul 27, 2011, 3:29:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cardinal
Ah, it's an inner class. Sorry.
[Jul 27, 2011, 3:30:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cardinal
I finished creating the VolumePlugin, exported to JAR, changed extension to sh3p and run. I got the message saying the plugin will work in the next run but there's nothing new in the menu :(
[Jul 27, 2011, 3:38:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cardinal
I solved the problem. I was exporting with the wrong options. Sorry for spamming.
[Jul 27, 2011, 4:14:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great you found out! smile
[Jul 27, 2011, 8:34:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
