Total posts in this thread: 5
Previous Thread This topic has been viewed 3437 times and has 4 replies Next Thread
Cardinal
A quick question about ControllerState subclasses
Hello,
Why do some subclasses of ControllerState override setState? Isn't it the same everywhere? (escape() then assign a state)? I don't get it.
Thanks for any help smile
[Jul 26, 2011, 10:22:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: A quick question about ControllerState subclasses
setState in PlanController class isn't overridden. It's only used in ControllerState when the state needs to be changed. See State design pattern and UML state machine diagram.
[Jul 26, 2011, 11:52:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cardinal
Sorry I meant setMode() not setState().
[Jul 27, 2011, 10:06:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Cardinal
Is it because you want to prevent self-transitions in some states in order to avoid exit() and enter() from running while the state did not actually change?
On a side note, setMode() in the ControllerState hierarchy is a bit confusing. The argument of the method (mode) is not being retained by the invoker, rather, an assignment is happening at the outer Class level. Thus, It's semantically incorrect to give this method a Setter naming style. A better name would have been switchMode or something to that effect. Correct me if I'm wrong.
[Jul 27, 2011, 11:51:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I guess I wanted to let a state controls what should be done when the user changes current mode.
On a side note, setMode() in the ControllerState hierarchy is a bit confusing. [...]
You're probably right, but I don't believe a lot of programmers are aware of the reason you mentioned... wink
[Aug 7, 2011, 2:49:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
