Some Questions (Rendering, Ubuntu, 64bit,....CAD)
hello,
i ve some questions about sweethome3d, i hope anyone can answer.
- is it possible to make more as one picture with the rendering function? i mean, i position (2x or 3x or 4x,..)the camera like in the video menü and sweet home make over night the different rendering pictures and save this in a custom folder.
- how can i use sweet home under win7 (64bit) as 64bit-programm? i try it with ubuntu-64, but unfortunately ubuntu is nothing for me.
- is it possible to accelerate sweet home rendering (or rendering plugin: advance rendering) ? Win 64 bit, 6gb Ram, DualCore 2x 2gHz Pixel ~2000x1400 Glossy / Turn on celling lights / Turn on lamps / Glossy Floors --> 3,5 hours
thats very slow
- is it possible to export the building/room in a CAD compaible format, like *.stp / *.igs / *.sat / *.wrl / ... ?
Re: Some Questions (Rendering, Ubuntu, 64bit,....CAD)
Ralf,
I don't have all the answers, but here's a start.
1 - more pictures in one go Unfortunately that isn't possible: one picture at a time. But it's a good idea for a feature request.
2 -accelerate rendering There isn't a "turbo" button in SH3D, but there are a few things that you should bear in mind: - the more lights (lamps, bulbs, etc) you add, the longer the rendering takes - make all models invisible that will NOT be visible in the image you're taking; this reduces the rendering time considerably
3 - CAD compatible formats SH3D saves/exports its data in OBJ format. Your best guess would be to use Blender or on online service to convert your model to a different format.
And by the way... 3.5 hrs isn't exactly bad for a 2000x1400 pix picture (depending on the file size). Also, programs generally run faster under Ubuntu than they do under Windows (I'm a Ubuntu-64 user).
Ralf,
1 - To install SH3D: From the Download page:
Under Linux: Uncompress the downloaded file and run SweetHome3D application found in the uncompressed directory. To install Sweet Home 3D, move the uncompressed directory in the one of your choice.
where can i find the .etek folder?
First it's .eteks not .etek You don't have to create it. To install a SH3P or SH3L file under Linux, right click on the file and choose to open it with the SweetHome3D program found in its installation folder.
Prefer the built-in renderer to the advanced rendering plugin. From David's tests, it's much faster. Please read also the FAQHow can I speed up the rendering process in photo and video creation panes?
See the FAQHow can I adjust the memory used by Sweet Home 3D?
java -Xmx4096m -jar path\to\SweetHome3D-3.2.jar
is it possible to make a shortcut?
i put the SweetHome3D-3.2.jar in my lib folder an make a shortcut on my desktop to this file.
but if i change in the properties from "C:\Program Files (x86)\Sweet Home 3D\lib\SweetHome3D-3.2.jar" to java -Xmx4096m -jar "C:\Program Files (x86)\Sweet Home 3D\lib\SweetHome3D-3.2.jar" windows show a error
Ralf,
Since you're new at Ubuntu, here are a few tips:
1 - To install SH3D you only have to unzip it. It will create a folder called SweetHome3D (or similar) with all the files and subfolders needed. You can place this folder wherever you want, because no programs point back to this folder. 2 - To run SH3D do this: open the folder in which SH3D is installed and look for the file called SweetHome3D. Its size is 771 bytes. Right-click on the file, select Properties, then click the tab Permissions. Make sure that the checkbox "Allow to run as a program" is active. Now close the dialog. Double-clicking the file SweetHome3D should run the program, although maybe you have to confirm this by clicking Run in a pop-up window. If all is well, you should now be able to use the program and make your first design. 3 - To find the .eteks folder, proceed as follows: open the file manager, then type CTRL-H on the keyboard. This shows all Hidden directories and files. Now you can locate the .eteks folder.
I hope this helps you get started.
