Total posts in this thread: 20
Posts: 20   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 9260 times and has 19 replies Next Thread
yizhou
The SH3D file failed to load on the web using Sweet Home 3D Viewer
Hi all, while open the file "SweetHome3DViewer.html" in the web browser to check if it works correctly, the message like this:正在加载家具模型...,but the SH3D file wasn't loaded successfully in the past 12 hours. What can I do? Thanks a lot~
[Apr 16, 2011, 6:51:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: The SH3D file failed to load on the web using Sweet Home 3D Viewer
I don't know if your problem is bound to the same problem as the one mentioned in this thread, but the version 3.1 of the viewer is buggy. Please, use the previous version 3.0, until the version 3.2 is released.
By the way, a translation of 正在加载家具模型 (even if partially accurate) would be helpful. wink
[Apr 17, 2011, 1:55:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yizhou
Thanks a lot Puybaret. Everything is fine now.
BTW, I want to edit the she3d file online, what can I do?
[Apr 17, 2011, 8:50:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yizhou
Ping...
[Apr 18, 2011, 4:34:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Editing the SH3D file is more complicate, because you have to decide how to load the file from the server, how to save it and who should be allowed to do these operations (that's why I don't distribute a compiled version Sweet Home 3D applet until now).
I can give you some hints but if you have no knowledge about web server programming technologies like PHP, JSP or ASP, this is going to be very difficult for you.
[Apr 18, 2011, 10:08:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yizhou
Hi Puybaret, thanks for your response~ Hmm,I think I have knowledge about web server programming technologies like PHP, JSP and ASP,so could you give me some hints? thanks again~
[Apr 19, 2011, 6:35:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You should download Sweet Home 3D source code, read its README.TXT file, run applet Ant target, test SweetHome3DApplet.html script, adapt readHome.php and writeHome.php files to your needs after reading SweetHome3DApplet parameters.
Reading also this thread and that one should be useful.
[Apr 19, 2011, 3:50:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yizhou
Thanks a lot Puybaret. Will do.
[Apr 19, 2011, 6:28:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yizhou
Hi Puybaret, while building Sweet Home 3D(http://prdownloads.sourceforge.net/sweethome3d/SweetHome3D-3.1-src.zip) with Ant,here no SweetHome3DApplet.jar in deploy/lib but SweetHome3D.jar. While testing SweetHome3DApplet.html, the error message like this:can't find class com.eteks.sweethome3d.applet.SweetHome3DViewer.Look like the class "applet" is missing in SweetHome3D.jar,right?
Thanks a lot~
[Apr 20, 2011, 8:14:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You have to run applet Ant target to build SweetHome3DApplet.jar file, for example with the command:
ant applet
[Apr 20, 2011, 10:57:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
