Germany
Re: Problem with Sweet Home 3D Viewer (3.0 and 3.1)
Hmseems to work now,but needs a really long time to load und needs additional a click into the applet to show up the romms now...but even better than nothing unless errors I don' t know why the former try of the 3.0 release didn' t want to work before,perhaps something went wrong in the unpacking of the zip...and perhaps there might be a performanceboost in a future version without needing an initial click? Nevertheless i will try to build a kind of Integrationway für my Drupal-CMS now where i have a working version...maybe as a set of Pagecode and Userprofilefield, because thats easier than building a module and i' m not a programmer as formerly mentioned *G*..(and then, when this wil work, i will release it here also)
"The social dynamics of the net are a direct consequence of the fact that nobody has yet developed a Remote Strangulation Protocol." -- Larry Wall
The bug fix mentioned in my previous message is available in version 3.2 of the viewer.
Sorry there's still a problem in version 3.2 of the viewer under Windows. I fixed it but you should still use version 3.0 till next version is released.
[Edit 1 times,
last edit by Puybaret at May 4, 2011, 7:16:39 AM]
I acquired a digital signature yesterday to sign the JAR files of the Java Web Start, Online and Viewer versions, and updated the JAR files hosted on sweethome3d.com web server and released a version 3.2.1 that fixes the bug fix in the viewer.
As installers didn't change, I didn't release a source code archive to avoid too much confusion for users visiting files list on SourrceForge.net. But if required you can download them with CVS and the V_3_2_1 tag as explained in Sweet Home 3D README.TXT file.
Germany
Now it works with the 3.3 Version of the Viewer...but theres one funny(?) thing which might be a bit irritating: When i view the page withing Windows 7 under Firefox 5.0.1 or any other Browser it shows up the result as expected, when i view it within Linux (opensuse 11.3) under seamonkey or firefox, i will first have to click once inside the appplets resultframe and then it shows up the result,otherwise the applet would show me only a gray frame instead of the view to the created rooms... Perhaqps is this last issue depending a bit on the used java Version? I use java-1_6_0-sun-1.6.0.u26-0.2.1.i586 on my opensuse linux clientsystem (i just ran all updates today from within my package-managementsystem and this was not updated)
When i figure out where the CMS Drupal 6.x (which i use on several Websites) searches for the Viewers Libraryfiles, i will publish a little Demo-Pagesourcecode for integrating the Viewer in Drupal-pages here, but actually drupal seems to ignore the given urls inside the applet-calling pagecode and seems to search in several wrong places for it ;)
