Total posts in this thread: 5
Previous Thread This topic has been viewed 3504 times and has 4 replies Next Thread
KriZ99
strange walls across my room
Hello,
I've used this sweet program today for the first time and realy like it. There's only one problem, I have: There is a strange wall across my room wich is only visable in 3D (Areal View and virtual visit). And there is a 2nd wall between the left window. When I delete all walls, the wrong ones disappear, too. But I don't manage it to get these two wall out of my project.
Maybe someone can take a look at my files and tell me, what I'm doing wrong. Thank you... klick
[Feb 7, 2011, 9:06:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: strange walls across my room
Kriz,
It's not a wall, but a stray part of a ceiling.
When your walls aren't the same height, SH3D cannot calculate a proper ceiling. This results in "strange" triangles, visible from one side, invisible from the other side. Make all walls 330 cm high, and they will disappear. If that is not possible, make the ceiling invisible.
You may also want to study how to insert doors and windows: the way you inserted the two green doors shows you didn't make an exhaustive study of the manual...
[Feb 7, 2011, 9:22:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KriZ99
Hello Hans!
Thank you, this helped! smile
Sometimes reading the manual really helps. cool
Now everything looks great.
Chris
[Feb 8, 2011, 10:50:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wrosun
Nepal
you really need to read the manual.i see you are using small wall heights to place windows into your model which is not necessary cause SH3D automatically creates a hole when you put your window or door model into the wall. Give sometime to read the manual and see the difference in the models you produced above and the perfect models you would be able to make with Sweet Home 3D.And remember to share your work in gallery forum for the world to see!
Wrosun.
[Feb 9, 2011, 1:48:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KriZ99
Meanwhile I found out, how to handle this. Works fine.
Definitely... smile
[Feb 9, 2011, 7:18:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
