Total posts in this thread: 34
Posts: 34   Pages: 4   [ Previous Page | 1 2 3 4 | Next Page ]
Previous Thread This topic has been viewed 34560 times and has 33 replies Next Thread
Re: 2 floor restaurant.
Fred,
You're the first to "complain" about this plug-in, so I assume it's working correctly.
You might try a slightly different way:
- select your model
- click Tools --> Copy as new furniture
- right-click and Paste it in your existing model.
- check that this works; the copy should be exactly on top of the original.
- if that works, open your target file
- switch back to the source file, select the copy you made and do CTRL-C
- switch to the target file
- click in the top-right window to give it focus
- do CTRL-V to paste it there
If this doesn't work, let your father, mother, wife, boyfriend/girl, neighbour try it. If neither of them manages it, there's something strange going on. Goblins?
[Dec 31, 2010, 3:58:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fintan
Happy new year Hans!
- select your model
It is goblin time sad
As you can see here:
But it does not paste into anything.
Neither the provenance nor the target.
Could this be a KDE 4.x.x thing??
[Jan 2, 2011, 11:39:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fred,
Thank you, and a Happy New Year to you too!
Your screen shot shows that the plug-in itself is working correctly. I'm not familiar with KDE, as I use the Gnome desktop. Have you tried using Edit --> Paste instead of the right-click or CTRL-C and CTRL-V?
[Jan 2, 2011, 2:00:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fred, I've got some doubts about your clipboard. Did you try whether a simple copy paste works or not?
[Jan 3, 2011, 8:50:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fintan
I am not sure what you mean by "simple copy / paste".
I will repeat (again) what I am doing here:
I open the gallery (the model I want to copy as new furniture) and the rest.bottom model (this where the "new furniture" is supposed to go).
Both models are now open.
I go to the gallery model select all and do:
tools->copy as new furniture.
This seems to work.
Now I switch over to the ALREADY OPEN rest.bottom model and try the following:
-right click on the model panel -> no paste option.
-using "edit" does not show a paste option.
-CTRL - V does not work.
Where does sh3d store the copy as new furniture?
[Jan 4, 2011, 8:49:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
By "simple copy / paste", I mean select an item in plan, choose "Edit > Copy" then "Edit > Paste", and check if the copied item was pasted.
[Jan 4, 2011, 10:03:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fintan
Okay, well in a word, no:
[Jan 5, 2011, 9:31:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Fred,
Can you install the Gnome desktop to see if that works?
[Jan 5, 2011, 12:30:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
yocarbo
FRANCE
Hello,
I "reopen" with topic because I have the same problem ! sad
I have KDE 4.4.8-3 on (K)ubuntu 12.04 and SH3D 3.5 with the last(?) plugin CopyAsNewFurniturePlugin-1.1.sh3p
After click Tools → Copy as new furniture, I can't paste the furniture.
I don't have any log in my konsole for debugging.
Have you find solution ?
Best regards,
[Aug 28, 2012, 11:48:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Yo,
I'm using Ubuntu 12.04 with a classic desktop, and I don't have any problems with SH3D 3.5.
Over time I've learned that the installed version of SH3D works best, because it comes complete with Java. If you have problems, first un-install all Java-versions, then download the installer-version of SH3D.
Most other problems are caused by graphics card or graphics driver problems, especially on older computers. Make sure to update your drivers, and in the FAQ read the section that deals with video issues.
[Aug 29, 2012, 1:40:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
