FRANCE
Re: 2 floor restaurant.
Hello,
Thank you for your response, but I used 2 différents PC DELL with ATI or Intel video card. I'm on 64bits, make a difference ? I use already the installed version. I have tested without java installed and in command line with different version of java (1.6.0_32 and 1.7.0_06) and executable jar : java -jar SweetHome3D-3.5.jar but no success
Yo,
One of the suggestions done earlier is to do a "normal" Copy-Paste operation. Example: Open your text processor Writer (?), type some text, now Copy and Paste it.
If that causes (more or less) the same problem(s), maybe something is wrong with the clipboard function.
One other thing about using CopyAsNewFurniture: the copy that you make, is put exactly on top of the original. Sometimes it may seem as if no copy has been made, when in fact (invisibly) the copy is right on top of the original.
One other cause of problems, in rare cases, is the model that you are trying to copy. If that model is faulty, than sometimes it may cause strange behaviour. You can easily test this by trying to copy some kind of standard furniture in an otherwise empty SH3D design.
Finally, maybe you can try a third computer with Ubuntu 32-bits installed? Or make a dual-install?
FRANCE
HANSMEX YOU ARE A GENIUS !
the solution is very simple ... pfff ! On KDE, an application manages the copy/paste : klipper ! I have desactivated this application and "bazinga", it's worked fine !
Thank you for your big help, I can continue my project for my house with this simple, efficient and magnifique program SH3D !
