Total posts in this thread: 6
Previous Thread This topic has been viewed 12510 times and has 5 replies Next Thread
Georgeinnj
how to drop the elevation of a room
Hi, I just started using SW3D a couple of days ago and have put together the first floor plan of our house by drawing the outer perimeter and then putting in the interior walls. One of the rooms is a step down from the other rooms but I can't find any option to change the level of that room. Do I have to recreate the house plan by using the create room method in order to change the elevation of that one room?
Regards
George
[Dec 5, 2010, 2:44:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: how to drop the elevation of a room
If you didn't find the option to change floor elevation, it's because it doesn't exist. wink
The only workaround is to place boxes at floor level that will simulate the elevation of the step.
[Dec 5, 2010, 1:52:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Georgeinnj
ok, sounds like it's back to the drawing board.
So, I would have to go back in and raise the elevation of all the other rooms by drawing a box in each room that fills the entire floor, and also raise the height of the wall so that each of those rooms are still 8 ft high. Is that correct?
[Dec 5, 2010, 3:18:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
George,
The easiest way to create a multi-level house, is to install and use the CopyAsNewFurniture plug-in. See the tutorial.
Draw each floor separately, then use Tools --> CopyAsNewFurniture to copy an entire floor and stack it on top of another floor.
There is a tutorial on how to build multi-level houses, but it's a bit outdated. I just finished revising it, but it hasn't been published yet. Send me your email address and I will send you the revised tutorial.
[Dec 5, 2010, 5:07:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Georgeinnj
Thanks, for pointing me at that plug in. I appreciate the help.
Please send the revised tutorial to [email protected]
[Dec 5, 2010, 5:57:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
boymoreubon
Great ! you did the way I'm Thinking, I'll do this Thanks out loud.
laughing
[Jan 7, 2011, 1:22:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
