the render stop before it finish
I'm using version 3 and i tried to use my last project and tried to render and I was hoping that the render is faster & more realistic. but render always stops before it finish actually. it stops after about 10 seconds, and button "save" is enabled before the render show its result
what did i do wrong? i installed version 3 before uninstall version 2.6
Re: the render stop before it finish
Yudi, please try with default Create photo feature. To be sincere, I'm not even sure I tried once the Advanced rendering photo during the development of Sweet Home 3D version 3.0. I should have but I didn't, and I'm not sure I'll maintain the plug-in anyway. Note that you can still use Sweet Home 3D 2.6 and 3.0 on the same computer.
Yudi,
A few things you could try:
1 - save your model, close SH3D, restart it, load your model and try again (I think SH3D has some strange memory allocation problems, and with a "clean" memory you can render bigger designs) 2 - (temporarily) delete furniture that doesn't show in the photo you want to make, then make your render in a clean machine 3 - (temporarily) delete plants and trees outside the visible area, as these take up a lot of resources during rendering 4 - share your file and I'll be happy to have a look at it
Yudi, You can send your file to me also if Hans suggestions don't fix your problem. I'll have a look at it with a debugger that will help me find the problem. Nice layout by the way!
Yudi,
Thanks for sharing your file. On my (Ubuntu) PC the render stopped after a few seconds. I'll have to investigate what the cause is. As soon as I know more, I will post it here.
EDIT I already have a suspect. The couch and the staircase are 3DS files, which you probably imported as a zip-file. Inside the file are also gsm-files. Try to unzip the file and import only the 3ds file, without the gsm part. Maybe that will solve the problem.
When I delete the three tangga files, the rest renders without a problem. END EDIT
[Edit 1 times,
last edit by hansmex at Dec 4, 2010, 4:21:22 PM]
The problem probably comes from one the 3D models, but not from the GSM files. I fixed the bug in the source code but... I won't be available until version 3.1 or an intermediate beta version. Thank you for sharing it help me to fix the bug.
