Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: the render stop before it finish |
| Print at Sep 14, 2026, 1:33:06 AM | View all posts in this thread on one page |
| Posted by fhoofman at Dec 3, 2010, 7:19:26 PM |
the render stop before it finish I'm using version 3 and i tried to use my last project and tried to render and I was hoping that the render is faster & more realistic. but render always stops before it finish actually. it stops after about 10 seconds, and button "save" is enabled before the render show its result what did i do wrong? i installed version 3 before uninstall version 2.6 ![]() |
| Posted by Puybaret at Dec 3, 2010, 7:28:50 PM |
Re: the render stop before it finish Yudi, please try with default Create photo feature. To be sincere, I'm not even sure I tried once the Advanced rendering photo during the development of Sweet Home 3D version 3.0. I should have but I didn't, and I'm not sure I'll maintain the plug-in anyway. Note that you can still use Sweet Home 3D 2.6 and 3.0 on the same computer. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by fhoofman at Dec 3, 2010, 7:45:21 PM |
Re: the render stop before it finish i'm afraid that using default create photo feature just give me the same result ![]() |
| Posted by hansmex at Dec 3, 2010, 8:31:46 PM |
Re: the render stop before it finish Yudi, A few things you could try: 1 - save your model, close SH3D, restart it, load your model and try again (I think SH3D has some strange memory allocation problems, and with a "clean" memory you can render bigger designs) 2 - (temporarily) delete furniture that doesn't show in the photo you want to make, then make your render in a clean machine 3 - (temporarily) delete plants and trees outside the visible area, as these take up a lot of resources during rendering 4 - share your file and I'll be happy to have a look at it Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Dec 3, 2010, 8:41:12 PM |
Re: the render stop before it finish Yudi, You can send your file to me also if Hans suggestions don't fix your problem. I'll have a look at it with a debugger that will help me find the problem. Nice layout by the way! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by fhoofman at Dec 4, 2010, 5:04:49 PM |
Re: the render stop before it finish I've done what Hans told me to. but seems not working yet. here's the file files feel free for anyone to learn my design ![]() |
| Posted by hansmex at Dec 4, 2010, 5:13:57 PM |
Re: the render stop before it finish Yudi, Thanks for sharing your file. On my (Ubuntu) PC the render stopped after a few seconds. I'll have to investigate what the cause is. As soon as I know more, I will post it here. EDIT I already have a suspect. The couch and the staircase are 3DS files, which you probably imported as a zip-file. Inside the file are also gsm-files. Try to unzip the file and import only the 3ds file, without the gsm part. Maybe that will solve the problem. When I delete the three tangga files, the rest renders without a problem. END EDIT Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Dec 4, 2010, 7:13:36 PM |
Re: the render stop before it finish The problem probably comes from one the 3D models, but not from the GSM files. I fixed the bug in the source code but... I won't be available until version 3.1 or an intermediate beta version. Thank you for sharing it help me to fix the bug. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by fhoofman at Dec 4, 2010, 8:29:50 PM |
Re: the render stop before it finish from my design, here's render from version 2.6 and here's from version 3 after deleting 2 tangga files I think i learn something here thanks Hans |
Current timezone is GMT Sep 14, 2026, 1:33:06 AM |
