OBJ Problem
Hi everybody,
I'm using this nice program to create the layout of my new home and I would like to export my project in OBJ file and run a render with dedicated programs. My problem is that when I try to export the OBJ file, most of the items present in the project are not included in the new file.
Re: OBJ Problem
Thank you for your suggestion. I will try soon your trick since I'm sure i have invisible objects. Unfortunately, I cannot share the file due to its big size. By the way: can be even a problem of file size?
Re: OBJ Problem
Maurosh,
There has been a similar incident, I believe. Start reading here , to see how strange a wall with texture can behave.
Known causes of problems are: - too large textures (over 1024x1024 pixels) - too large files - certain DAE/Collada files, especially low-poly models - too many textures - not enough memory
At www.mediafire.com you can upload large files. Downloading is not a problem.
Re: OBJ Problem
Maurosh,
After downloading your file, I had a quick look at it, and did a test-render in v3.0 and v2.6. I can't see any problems.
When inspecting the sh3d-file, I noticed that the granite texture (item #89) is 1600x1200 pixels. You might consider making it smaller, e.g. 800x600 pixels. This would make rendering more reliable and faster without affecting the result.
Also, your walls are semi-transparent, maybe this causes strange effects when exporting.
Re: OBJ Problem
Thanks Hans, but the problem seems to be different. I tried to export the OBJ file without granite texture and with solid walls but the result is the same. I have just the wals and sofa in the obj file.
Regarding the internal rendering I have instead no problems.
