Total posts in this thread: 2
Previous Thread This topic has been viewed 4794 times and has 1 reply Next Thread
charankalcut
How To Fix Walls
Hi all! Is there any way to fix the walls so that nobody can resize
the walls?
Thanks is advance
[Oct 19, 2010, 9:14:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How To Fix Walls
Charanjeet,
That depends on what you want EXACTLY.
1 - Fix walls so they won't be accidentally deleted: use Plan --> Lock base plan
2 - Fix walls so users can change the entire plan, but not the walls: not possible
3 - Allow users to view the model without changing anything: use the viewer
There is, however, a workaround.
- Install the plug-in CopyAsNewFurniture (see tutorial )
- Make your design with walls, floors and roofs, and save it.
- Insert at least ONE piece of furniture (doors and windows also count as furniture)
- Use Tools --> Copy as new furniture to copy your design.
- Open a new instance of SH3D and paste your new furniture into it.
- Use this fixed model to make the rest of your design.
Good luck
[Oct 19, 2010, 11:52:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
