Re: How To Fix Walls
Charanjeet,
That depends on what you want EXACTLY.
1 - Fix walls so they won't be accidentally deleted: use Plan --> Lock base plan 2 - Fix walls so users can change the entire plan, but not the walls: not possible 3 - Allow users to view the model without changing anything: use the viewer
There is, however, a workaround. - Install the plug-in CopyAsNewFurniture (see tutorial ) - Make your design with walls, floors and roofs, and save it. - Insert at least ONE piece of furniture (doors and windows also count as furniture) - Use Tools --> Copy as new furniture to copy your design. - Open a new instance of SH3D and paste your new furniture into it. - Use this fixed model to make the rest of your design.
Good luck
