Total posts in this thread: 135
Posts: 135   Pages: 14   [ Previous Page | 3 4 5 6 7 8 9 10 11 12 | Next Page ]
Previous Thread This topic has been viewed 342470 times and has 134 replies Next Thread
Re: Sweet Home 3D 3.0
And here are the results of the big render lottery:
First run:
Q0 = 3x correct
Q1 = 3x correct
Q2 = left is white
Q3 = 3x correct
Second run
Q0 = 3x correct
Q1 = 3x correct
Q2 = left is white
Q3 = left is white
Third run = see: first run
Fourth run
Q0 = 3x correct
Q1 = 3x correct
Q2 = 3x correct
Q3 = left is white
Fifth run
Q0 = 3x correct
Q1 = 3x correct
Q2 = 3x correct
Q3 = 3x correct
Sixth run = see: fifth run
Seventh run = see fourth run
Have fun!!
[Oct 17, 2010, 2:52:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PtiNounours
I think the problem probably comes from the left wall of the right orientation of faces sketchup. it's really strange, but I would be careful about that now.
Hans, I see you've textures of the 3 walls Q0 and Q1, I have rarely textures displayed in these two qualities, either in photo or video. Only the colors and not textures are displayed in my home at Q0 and Q1 sad
[Oct 17, 2010, 3:19:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe it's Ubuntu? My version of Java? My video card or drivers? There's a lot of variables in the equation...
[Oct 17, 2010, 3:29:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
This is my latest rendering with the beta:
http://www.storm-artists.net/full/98629
[Oct 17, 2010, 10:29:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PtiNounours
Beautiful spacious kitchen
[Oct 18, 2010, 12:08:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I searched the bug described by PtiNounours and tested by others.
It's really weird and looks like that's a bug in SunFlow rendering engine. Sometimes it doesn't even try to render the texture applied to the left object. Investigating might be much more complicated than expected... sad
[Oct 18, 2010, 11:35:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
Maybe there are a few things connected here?
1 - The strange behaviour Sebastien noticed
2 - The strange behaviour I noticed with textures and transparency.
Maybe a complete "reformulation" of how textures are applied could be a solution? The fact that the tests on Sebastien's file gave different results for every run, is very strange.
I am compiling a kind of document with info on how OBJ files work, but it's very hard to find a complete and easy to understand manual, that goes into enough detail to explain what I need. Ideally I would like to construct an OBJ file for a cube that does what >>I<< want, and not what some-one else wants :-)
[Oct 18, 2010, 11:52:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry Hans, but reversed textures and Sebastian wrong rendering are completely unconnected. Good try, but this won't help! sad
About the OBJ format, create a new thread where you'll ask your questions about it. It's really not a complicated format for a programmer.
[Oct 19, 2010, 6:54:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
Thanks PtiNounours!
[Oct 19, 2010, 6:22:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
whippetsleek
Maybe someone has figured out a way to do this... But I seem to be having a lot of trouble splitting the circular walls and keeping my radius the same size. I can't split the walls to paint them different colors, nor to resize the wall without it moving both end points and changing size. I can make many separate circular walls and do what's needed to be done, but I would like to know if anyone has found a faster way.
Thanks! smile
[Oct 22, 2010, 12:08:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
