Re: Sweet Home 3D 3.0
The Beta 21 brings Hungarian, Spanish and German translations and a correction to an annoying bug that prevented overlapping floors from being correctly displayed. I thought I fixed it last May, but in a certain way, it was worse because many videos made with OpenGL quality were blinking at ground level because of the fix. This version brings also two small improvements: - Photo and video creation dialogs are reopened at their last location if they won't be partially hidden, - Modified status of a home is switched to true when you change point of view list and parameters in photo and video dialogs.
By the way, I might have forgotten to post a Java library required to test the new settings of rendering quality mentioned in my previous message. Sorry, and I still hope to read your thoughts about it.
Emmanuel,
A quick test shows that v3b21 performs VERY well.
Image 1: glass is transparent, mirror reflection is good, shiny surfaces show correct. Only a bit of moire in top-left corner of mirror, but that's why I picked that green texture. I'll see if I can make some more scenes for further testing.
Image 2: visible are the window and tree, the firefighter, three light bulbs that illuminate the scene.
Image 3: here too everything seems just fine. I only see one problem: the tulips looks so nice, that I'm afraid they won't last long...
[Edit 2 times,
last edit by hansmex at Nov 23, 2010, 9:10:20 AM]
I'd like to post some details about PtiNounours bug seen earlier in this thread. I looked at the Wall_test.dae.obj file defined in test_wall.sh3d contained in the file he posted, and found why this imported part caused a problem. This OBJ file contains 2 shapes: - the exterior of the wall object with normals pointing towards the exterior of the object and with a wall texture, - the interior of the wall object with normals pointing towards the interior of the object; this second part is white.
It's a similar bug to this one where SunFlow didn't handle correctly the double sided triangles of one shape, but this time the bug is at a higher level. Instead of having twice the same triangle (one oriented in a clockwise order, the other one oriented in a counter clockwise order) in one shape, you have two shapes with the same triangles oriented differently; one of the shape uses a texture and the other one is white. OpenGL handles these two shapes nicely because it ignores the faces with a normal that doesn't point towards the observer. At the opposite, SunFlow renders all the faces without taking into account whether its normal points towards the observer or not. So sometimes it chooses the textured face, sometimes the white face. Fixing this isn't easy because it's two separated shapes and not twice the same triangles within a shape. But you can also avoid the problem by following PtiNounours' suggestion.
This thread created by Hans is about the same bug.
Hello Emmanuel,
Just found that beta 23 is out. When doing a render of a model made with a previous version, I noticed something strange. With Q0 and Q1 the model renders white, but with Q2 and Q3 all textures render the way they should.
Maybe you made a typo somewhere?
The Beta 25 brings more translations and new help pages about photo creation, video creation and compass modification in English and French. I think that miserably, these new pages won't be translated to other languages in the coming version 3.0, and users of other languages will have to wait a little longer to get this new information in their language. This beta fixes also the wrong rendering of compass under OpenJDK reported by Pencilart (it's not perfect but it's better though).
Hans, Sometimes textures are not rendered correctly in offscreen images (used during printing and Q0 / Q1 rendering). As this bug happens randomly, I'm afraid it's not a bug in Sweet Home 3D but in Java 3D but I should investigate it better. It's probably the same bug as this one.
Nepal
I dont understand any thing i also wouls like to render pictures like these but i dont understand what Q0,Q1,Q2,Q3 are.....i am not new in sweethome 3d but rescently started to use the forums........would like to learn more and interacte more wid guys like you....
