Total posts in this thread: 4
Previous Thread This topic has been viewed 4976 times and has 3 replies Next Thread
leonelpedron
Problemas en vista 3D
Instale una version anterior creo la 2.1 y luego el paquete de plugins, y tengo este problema en como se ve en 3d.
Desintale todo y puse la ultima vesion 2.6, pero sigo con el mismo problema, en otra pc instale directamente la 2.6 y se ve perfecto.
este es el problema:
[Aug 31, 2010, 3:28:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problemas en vista 3D
TRANSLATION
I installed an earlier version, I think v2.1, and then the package of plug-ins, and (now) I have this problem with how 3D looks.
I uninstalled everything and then installed v2.6, but I still have the same problem. On another PC I directly installed v2.6 and it looks perfect.
This is the problem:
<image with problem>
[Aug 31, 2010, 3:58:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Intenta DirectX solución:
FAQ.
[Aug 31, 2010, 5:43:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
leonelpedron
Le cargue la actualizacion del driver de video, sin resultados.
Lo pude solucionar agregando el archivo SweetHome3D.l4j.ini
Muchas Gracias !!!.
Traduccion:
I load the video driver update, to no avail.
I could fix this by adding the file SweetHome3D.l4j.ini
Thank you very much!.
[Sep 1, 2010, 1:09:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
