Total posts in this thread: 4
Previous Thread This topic has been viewed 7434 times and has 3 replies Next Thread
edice
Resize entire plan
I built my sweethome plan by tracing my house plans.
Now, after some measuring of the house, I release the original scale was not correct (or the plans weren't correct), and the whole house is a little bit too big.
Is there a way I can resize the entire house by a percentage?
thanks
Paul
[Aug 22, 2010, 3:46:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maker
Re: Resize entire plan
As far as I can see, the only way is to export as OBJ.
Open in Wings3d or similar program.
Scale it there.
Import as furniture.
But maybe someone can come up with a better idea
Good luck ;-)
[Aug 22, 2010, 7:14:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
starrunner
You could use this new plugin:
Advanced plan editing
It has the resize action, you are searching for.
After installing you just need to select all items in the plan ([Ctrl]+[A]) and open the resize dialog in Edit->Resize.
[Sep 15, 2010, 12:27:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Paps72
Why don`t Import as a new Furniture, and make it there bigger, or smaller???
That is possible, when you exmport the Project (or maybe splitted in parts) as .OBJ (Must all parts been marked, or that, what you want to resize/copy).
Best way, I make it, with the "Copy as new Furniture" Plug in.
But before, check the size of the walls!
Maybe walls to slim?!
[Sep 25, 2010, 6:52:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
