Resize entire plan
I built my sweethome plan by tracing my house plans.
Now, after some measuring of the house, I release the original scale was not correct (or the plans weren't correct), and the whole house is a little bit too big.
Is there a way I can resize the entire house by a percentage?
Re: Resize entire plan
You could use this new plugin: Advanced plan editing It has the resize action, you are searching for. After installing you just need to select all items in the plan ([Ctrl]+[A]) and open the resize dialog in Edit->Resize.
Why don`t Import as a new Furniture, and make it there bigger, or smaller??? That is possible, when you exmport the Project (or maybe splitted in parts) as .OBJ (Must all parts been marked, or that, what you want to resize/copy). Best way, I make it, with the "Copy as new Furniture" Plug in. But before, check the size of the walls! Maybe walls to slim?!
