How to make a roof light and a corner sink?
How can I make / use a horizontal roof light and a corner sink (from corner to both sides 90 cm)?
Actual (none Beta) stable, portable Sweet Home 3D Windows 7 Premium Home Edition & Vista
Re: How to make a roof light and a corner sink?
Lights can be only point lights until now. You'll have to build the corner sink from a basic sink that you'll surround with triangle and boxes, or probably better with an other program like AOI or Blender.
Thank you Emmanuel,
Okay, doesn't seem to be that easy...
Thanks again, nice greetings, Dirk
Alternative suggestions: 1.You can add multiple lights in an array to simulate the roof-light. 2.You can use poseray ( http://mysite.verizon.net/sfg0000/ ), import OBJ files.Then convert your light to "array" and use povray renderer (povray.org) to render. 3. Import OBJ in Kerkythea (www.kerkythea.net), replace lights/materials as needed, render.
Many thanks maker,
Yes, of course, it helps. I will try...
Many thanks again, above all for the links. Nice greetings, Dirk
