Total posts in this thread: 2
Previous Thread This topic has been viewed 3946 times and has 1 reply Next Thread
beral
Is there a way to add simple graphics
I'm looking for a way to add simple 2D graphics, for example a line, rectangle or circle. I guess for a rectangle I can use a box with minimum height and no fill, but I'd like to be able to draw a circle around a round table and chairs to show the effective boundary of the set (I'm trying to model a church hall set up with round tables for a party, to see how many tables I can get in). All suggestions and work-rounds appreciated!
[Jun 24, 2010, 11:56:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Is there a way to add simple graphics
Beral:
Here's a workaround.
Import this model and make sure its orientation is correct. Combine 4 to make a circle, and use Group , or Export as OBJ, or Export as furniture . You can than give it any height (close to zero) and diameter to indicate the space a round table with chairs occupies.
In the same way you could make an object from 4 thin boxes and export/import it to form a square.
[Jun 25, 2010, 1:35:54 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
