Total posts in this thread: 253
Posts: 253   Pages: 26   [ Previous Page | 4 5 6 7 8 9 10 11 12 13 | Next Page ]
Previous Thread This topic has been viewed 3694953 times and has 252 replies Next Thread
Voytkostudios
Hello,
I'm having an issue with the Library Editor. I can save files, but these .sh3f files can only be opened in the Library Editor and are only visible when opening files in this program. They are not visible in windows explorer or Sweet Home 3D. Is this a known issue? I'd appreciate any help.
Thanks!
[Aug 21, 2015, 3:57:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If the .sh3f files you created are not visible in Windows explorer, how could you choose them in Sweet Home 3D to import them?
You probably saved them in a folder that is not the one you expected.
If you want, you can also send me a .sh3f file to test it on my side, but as you can't find them, it's going to be difficult for you to attach one of them to an email!
[Aug 21, 2015, 9:59:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LunaC
Germany
I LOVE this program! Thanks so much for publishing. However is it possible to make it use a standard language for all sh3f files? The preferences lets me set it to english but there is more than one english (AE, BE,...) and I wish it would just stick to the same whenever I load a file.
Thanks!
[Jan 20, 2016, 1:05:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LunaC
Germany
rose Re: Furniture Library Editor released
Hi, I have some feature request to the plugin:
- add a simple search box for larger databases
- show number of files in database
- make the preview image bigger e.g. when changing the column size
- a possibility to choose which columns to show
- make it remember the last path used or a possibility to add a standard folder
-some kind of search for duplicates (posted that in the request area for the program itself already)
Well hats it (for now) I have no idea how complicated it is but I would really love to see any those features rose
[Jan 21, 2016, 2:44:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LunaC, don't use preferences settings to give the translation of the 3D models you added to your library. The language setting in preferences is used just to change the language used in the user interface of the Editor, nothing else.
You should rather choose the language in the dropped down list shown in the tool bar of the icon. This list provides all kind of languages, possibly with their variant in some countries. When you select a language different from the Default language, the Editor prepares an additional properties file in the sh3f file for that language, suffixed by language + country codes (for example, PluginFurnitureCatalog_en_GB.properties for English UK variant, or PluginFurnitureCatalog_de.properties for default German). Then, all the modifications you make on the name, category, keywords and information of the edited models will be considered to be in the selected language (and stored in that suffixed file). If you want to edit the models in the default language again, just select Default language. See the simple example attached to this post.
You can prepare how many translations and variants as you want for your library. For example, Sweet Home 3D models libraries are proposed in 21 languages, with country variants for Chinese and Portuguese languages. When a library is translated in a certain language, it appears in bold in the language dropped down list.
Note that if you want to force a country in Sweet Home 3D that is not yours, you can use the Java -Duser.country option followed by 2 capital letters ISO 3166 country code. For Australia, it will be:
-Duser.country=AU
About your feature requests, note that you can find more easily a model in the current version by sorting the library by name, category... when you click on its column header.
If the icon got bigger when you enlarge its column, the row should grow accordingly, a reason why I don't think I'll program this feature. Nevertheless, keep in mind that a tool tip displays the icon of a model at a bigger size when you place the mouse on its icon.
Attachment Box.sh3f (2349 bytes) (Download count: 2552) (A simple library with UK variant)
[Jan 22, 2016, 2:06:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
LunaC
Germany
Thank you for explaining this all to me.
Id love to use the Java-Duser but how do I do that? I don't have a program to work with java. As far as I could see from the iso codes there's none for just general english but GB would be ok for me too. Could you maybe send me that file that I need or explain/point me to a source that shows how to do this?
Thanks for your Box.sh3f but it still doesn't solve the problem I have. When I open it in Furniture Library Editor the dropdown has set "default language" when I edit the file now e.g. adding keywords and then safe it and reopen it again those keywords are visible under "default language" but not under "english (uk)" or in case of my other files under "english" without country specification.
So whenever I want to edit a file in Furniture Library Editor I have to remember to set the drop down to the language I want. If I forget it I sometimes add keywords for hours and then see I can do it all over again because it saved it to whatever it thinks is the default language.
My computer is set to german but I use the program in english (I use many programs in english because tutorials are often only written in that language).
If I would have a -Duser.country=GB would it tell the Furniture Library Editor that this is my default language and I could work with it without always having to choose from the dropdown first?
[Jan 28, 2016, 2:08:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
XroM
Россия
Crash after import new furniture or open a library sad
C:\Users\Roman\Downloads>java -jar FurnitureLibraryEditor-1.19.jar июн 24, 2016 11:54:40 AM java.util.prefs.WindowsPreferences <init> WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5. Java 3D: implicit antialiasing enabled Java 3D ERROR : wglGetExtensionsStringARB not support ! - ═х эрщфхэр єърчрээр яЁюЎхфєЁр. Fallback to use standard ChoosePixelFormat. Java 3D ERROR : OpenGL 1.2 or better is required (GL_VERSION=1.1) javax.media.j3d.IllegalRenderingStateException: GL_VERSION at javax.media.j3d.NativePipeline.createNewContext(Native Method) at javax.media.j3d.NativePipeline.createNewContext(NativePipeline.java:2775) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4914) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2440) at javax.media.j3d.Renderer.doWork(Renderer.java:917) at javax.media.j3d.J3dThread.run(J3dThread.java:275) DefaultRenderingErrorListener.errorOccurred: CONTEXT_CREATION_ERROR: Renderer: Error creating Canvas3D graphics context graphicsDevice = Win32GraphicsDevice[screen=0] canvas = com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas0,0,0,128x128]
Can anybody help me please?
Windows 10 x64
java version "1.8.0_91"
Java(TM) SE Runtime Environment (build 1.8.0_91-b14)
Java HotSpot(TM) 64-Bit Server VM (build 25.91-b14, mixed mode)
[Jun 24, 2016, 12:17:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I wonder if you don't have the same issue as some Windows 10 users who tried Sweet Home 3D installer 5.2. Then the solution would be to install and use Java 8u51, or to use the Java version which comes with Sweet Home 3D 5.3 with a command similar to:
"C:\Program files\SweetHome3D\jre8\bin\javaw.exe" -jar path\to\FurnitureLibraryEditor-1.19.jar
Just be sure to check the path of javaw.exe and FurnitureLibraryEditor-1.19.jar. The easiest way would be to drag and drop these files from the Windows explorer window to the cmd window.
[Jun 24, 2016, 3:15:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Here's the special version 1.20 of the editor with IDs [edit: removed link, IDs can now be displayed with an option in preferences].
It fixes an issue that generated an invalid SH3F file as soon as an icon or model file was referenced more than once in the edited catalog (issue fixed in version 1.18 of the standard editor).
[Edit 1 times, last edit by Puybaret at Aug 10, 2022, 1:58:49 PM]
[Jan 19, 2017, 10:23:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Never said thanks for this. ID field is greatly appreciated. So thanks.
But also - a special thanks for the SVG input field. It is ever so nice to have the SVG path light up in red to tell you about typos. Actually, I would really have wished for that in my normal editor. Not that I ever make typos, of course ... smile
PS It really would be nice if the FurnitureLibraryEditor (also with the extra fields for doors/windows/light-sources) at some point were included as an Advanced Model Option in SH3D itself. It would save some model-making time and would increase the power of SH3D enormously. But I also understand your hesitation when it comes to the interface. And I guess I am repeating myself...
[Mar 22, 2017, 5:59:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
