Re: Sweet Home 3D 2.4
Nice image db4tech!
I released version 2.4 tonight. I'll have to update Advanced rendering plug-in.
Emmanuel:
Maybe I'm too quick with this post of my test with v2.4.
From left to right: - The standard render in the 3D pane - The "old" photo render - The new Phong render (all 3 plug-ins have this problem)
The gentlemen are zip-files from the Google Sketchup library in the Collada file format.
Nevertheless, you've done a terrific job once again!
[Edit 1 times,
last edit by hansmex at May 25, 2010, 11:37:42 PM]
Emmanuel congratulations on your 2.4 release.
You've been busy!
Thank you for your kind remarks about the render, please feel free to use it if you want to. I might export the picture of the lady and add a background to it, then import and re-render, at the moment with the picture just being an outline it causes multiple shadows making the picture look like it's out of focus. Might also alter the desk lamp so it isn't so bright.
Hans, After reading your post I also gave the figures a try and concur they render (or rather they don't) as invisible. with any of the 3 new advanced shaders.
Emmanuel, Once again congratulations, thank you for all your hard work!
Thank you guys for your remarks and help! I know why the plug-ins don't work with DAE/Collada models, and will release a new version soon.
Thank you Emmanuel for the fixes, I can indeed confirm that the models render okay with every shader version (apart from some silver surfaces using Uber, please see below)
With you being very busy releasing version 2.4 I do hope my updated post on the lighting shader test thread (about a possible solution to the grey/silver leaves and furniture) will be helpful for the next version of Uber.
Couple of quick questions. Why did you choose to remove the advanced photo plug-in page from the front page? I have tried looking for it but so far haven't found it. Also with you releasing 2.4 yesterday what's your thoughts on the release date reading 25th instead? I know the date doesn't really matters just thought I'd ask.
Thank you for your time and especially for your hard work, db4tech
I can indeed confirm that the bug is now fixed. db4tech
After further tests I and sorry to report the bug is still there but to a much smaller extent.
The catalog view still creeps down the the screen and across by only a small percentage, maybe about 5 pixels at a time. Watching the program open I would guess you programmed in a negative jump distance so as the windows try to reposition/jump it should end up back where is started. Is that how you did it?
If it is helpful I have attached a couple of files to show how far the windows move after 10 saves
Save 1 The reference point to gauge against. Save 10 is the last save I did.
If I did more saves the windows would creep further but I thought 10 saves was enough to let you see what is still happening.
Sorry to report a bug db4tech
---------------------------------------- save 1.sh3d
(3277 bytes)
(Download count: 1421)
---------------------------------------- save 10.sh3d
(3310 bytes)
(Download count: 1601)
I know it's still not perfect, but the way Sweet Home 3D is programmed prevents me to easily fix it and this behavior varies from one system to the other (I prefer to avoid too much technical details here). The workaround is to resize the window with the mouse to get a size as large as the screen's size without using the maximize icon.
When I conducted my original tests, I did try enlarging the interface without using the maximize button, to see if the window positions stayed constant, which they do, the only problem is, it is very easy to forget when switching applications, if instead of minimizing Sweet Home, I just move the interface window slightly off screen (so some of the desktop is available) then on returning to use Sweet Home, without thinking double click anywhere the title bar which is my preferred method to maximize an application.
I can understand you not wanting to get too technical, so keeping it simple, which is prefect for me! With the windows positions creeping (or changing) I'm guessing their current horizontal and vertical positions aren't defined by a percentage calculation when the interface is maximized? As that figure would never change no mater what the users screen resolution or aspect ratio.
Thank you for your reply and offering a workaround. db4tech
