Total posts in this thread: 2
Previous Thread This topic has been viewed 3532 times and has 1 reply Next Thread
architetto20
sad The rendering doesn't start.
Hi everyone, I'm using Sweet Home 3D. When I launch the "Create 3D Photo" command, the window opens and then freezes on the first rendering frames. I tried closing the program and reopening it, but when I repeat the command, the rendering window freezes and an "X" appears. Help! sad sad
[Aug 22, 2025, 2:26:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: The rendering doesn't start.
This may happen when the program don't have enough memory at disposal. Try to increase the maximum memory Sweet Home 3D may use by following these instructions.
If it doesn't fix your issue, try to remove some furniture from your design removing the big ones first (display the Model size column to help you find them).
[Aug 23, 2025, 4:07:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
