Total posts in this thread: 5
Previous Thread This topic has been viewed 3942 times and has 4 replies Next Thread
procustex
how to add elevation to a wall and make a beam on the roof
Hi, my wall is made as this:
wiev by side
roof
__________
................|beam
................|_____
........................|wall
this format seems that doesn't allow to insert spaces so don't take into account the dots and consider them as spaces
I didn't succeed to insert an image
how can I get this?
[Jun 8, 2025, 10:21:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: how to add elevation to a wall and make a beam on the roof
To show images: upload your image to an image host like mediafire or imgur and post the url here.
Your drawing is not very clear so show an image to get useful advise.
[Jun 10, 2025, 11:08:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
procustex
ok thanks, this is the figure
https://paste.opensuse.org/pastes/1a09f8246d86
ciao
[Jun 10, 2025, 2:45:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I don't see a problem with this. You can create the beam using a box and elevate it so it's flush with the top of the wall.
I assume that the beam is on the outside of the wall and that you want the roof to extend over the beam. It depends on what kind of roof you want but the easiest way is to use the Generate roof plugin to create a roof.
If you don't have that plugin installed, you should install the Plugin Manager (direct download) and use that to install and keep up-to-date other plugins. Read more about it here .
[Jun 10, 2025, 4:15:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
procustex
manythanks, I used miscellaneous>box and it works
[Jun 10, 2025, 7:58:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
