Total posts in this thread: 4
Previous Thread This topic has been viewed 6805 times and has 3 replies Next Thread
Antonio.A
Uninstall from Ubuntu 22
Hi all!
My OS is Ubuntu 22.04.5 LTS
I have SweetHome3D ver.7.3 installed (and running OK).
After update, I have also SweetHome3D ver.7.5 installed (and running OK).
How can I remove the old version 7.3?
Thank you in advance.
[Feb 16, 2025, 5:24:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Uninstall from Ubuntu 22
Just leave it. You have a working version 7.5 so use that.
If you know where the 7.3 version is installed you could remove it but make sure you leave the user directory untouched. Both versions probably use that same base.
[Feb 17, 2025, 11:28:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Antonio.A
I agree, but I only have a little knowledge of Ubuntu: how can I find SweetHome3D ver.7.3 installation?
Then does exists an uninstall procedure?
[Feb 20, 2025, 9:32:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
As far as I know there is no uninstall procedure unless you installed through the repository. Then you can uninstall using the repository but make sure you first create a back up of the /home/<username>/.eteks directory because that might be uninstalled too (I never used/tried it). That is where your preferences and installed libraries/plugins are, you want to keep that for the new version. Note that '.' before 'eteks' indicates a hidden directory. In the file manager you have to switch on "Show hidden directories" to see it.
On Debian the directory is /usr/share/sweethome3d when installed from the repository but if you installed using the downloaded .tgz it is where you extracted that .tgz.
(The "eteks" name might change now that Sweet Home 3D is taken over by Space Mushrooms)
[Feb 20, 2025, 10:21:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
