Re: Imported object preview on plan is broken
Sometimes downloaded models have problems that can be solved by export/import. Try exporting the model and then import it again. Export: Menu > 3D view > Export to OBJ format, Import: Menu > Furniture > Import furniture
Thanks for your answers.
It seems the problem happens only on Ubuntu. I tested with Windows (the installer version from Sourceforge, not the one provided through the App store) and it works fine.
Under Ubuntu, I'm using the tgz install, with the included runtime which is 1.8.0_202 (Java3D is 1.6.2a - JOGL 2.5.0)
If you start with the script SweetHome3D try the other script: SweetHome3D-Java3D-1_5_2, works perfectly for Linux
