Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Imported object preview on plan is broken |
| Print at Sep 15, 2026, 3:14:46 AM | View all posts in this thread on one page |
| Posted by Bereldhuin at Feb 15, 2025, 6:22:06 PM |
Imported object preview on plan is broken Hi, Everytime I'm importing an object, the preview in the plan is always broken. However, the model is correctly imported and is working fine in the 3D view. Here is an example of a vacuum: Preview while importing (OK) : Preview in the plan (broken): 3D Visualization (OK): I'm using SH3D 7.5 on Ubuntu 24.04. Do you have any idea on how to solve this ? Thanks for your help, Fred |
| Posted by Keet at Feb 17, 2025, 11:26:05 AM |
Re: Imported object preview on plan is broken Sometimes downloaded models have problems that can be solved by export/import. Try exporting the model and then import it again. Export: Menu > 3D view > Export to OBJ format, Import: Menu > Furniture > Import furniture ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Feb 17, 2025, 12:51:42 PM |
Re: Imported object preview on plan is broken What Java version do you use (see About dialogbox)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Bereldhuin at Feb 17, 2025, 1:49:13 PM |
Re: Imported object preview on plan is broken Hi, Thanks for your answers. It seems the problem happens only on Ubuntu. I tested with Windows (the installer version from Sourceforge, not the one provided through the App store) and it works fine. Under Ubuntu, I'm using the tgz install, with the included runtime which is 1.8.0_202 (Java3D is 1.6.2a - JOGL 2.5.0) |
| Posted by Bereldhuin at Feb 17, 2025, 1:53:47 PM |
Re: Imported object preview on plan is broken Looking in the preferences, I changed the "Furniture icons in plan" to "Top view" and objects are now displayed correctly. However, it's still not the case in the left panel. |
| Posted by Keet at Feb 17, 2025, 2:03:27 PM |
Re: Imported object preview on plan is broken If you start with the script SweetHome3D try the other script: SweetHome3D-Java3D-1_5_2, works perfectly for Linux ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 15, 2026, 3:14:46 AM |
