Total posts in this thread: 4
Previous Thread This topic has been viewed 1877 times and has 3 replies Next Thread
mikeecho
South Africa
2D display of items still not working properly
item 1 at elevation 138 and height 10
item 2 at elevation 100 and height 500
In 3d view its 100%
In 2d view item 1 appears over item 2, even though item 2 is MUCH TALLER than item 1.
Seems that Sweet Home does not take the height of an item into account at all on the 2d, only the elevation, which is a DISASTER and sadly makes it unusable as a real design product
[Aug 17, 2024, 10:17:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Waldemar.Hersacher
Germany
Re: 2D display of items still not working properly
In 2D view the sequence of the items depends on the sequence in the furniture list.
You need to exchange the position of item 1 and item 2. Which only will help if the are in the same group. Otherwise you need to exchange the groups.
MSI GP60, Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy, SH3D 7.5 with Photo-video rendering 2.8
[Aug 17, 2024, 10:44:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
In the 2Dview items are stacked according to their elevation. That's why your item 1 shows on top of item 2 in the 2Dview.
Like Waldemar said, grouping can solve that. In a group the order of the items determines which is shown on top.
If you want a specific item in a group to be on top then there's a little trick to do this: select the item in the group and cut it. Select the group and right click, select 'Paste to group' from the context menu. Now the item is the last item in the group and should show on top. Knowing this you can create a group in the order you want by selecting the items in that order before grouping, last one selected is the one on top.
[Aug 17, 2024, 11:28:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mikeecho
South Africa
applause Re: 2D display of items still not working properly
AWESOME, that works!
Thank you so much, thought there must be a solution applause
[Aug 18, 2024, 2:22:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
