Total posts in this thread: 2
Previous Thread This topic has been viewed 1944 times and has 1 reply Next Thread
zeusweb
DE
Disable / Hide objects in plan while showing them in 3d?
is it possible to hide an object (-group) in the plan, while still showing it in 3d View?
Background:
I have a room with a slope ceiling, which I created as objects.
Now I want to see the ceilings in the 3d view. However, they block/hide everything in my plan view, so I can't edit my furniture...
Thanks for all tips and hints!
Regards,
Nico
[Jun 13, 2024, 11:00:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
Re: Disable / Hide objects in plan while showing them in 3d?
Alternative: Create a new level at the same elevation. Put your ceiling objects on this new level, and make sure the level is "above" or after, the level with your furniture. Then select "Display all levels" in your 3D view. Now you can work on your furniture in the plan view without the ceiling objects being in the way. However they will still be displayed in the 3D view. If you have additional levels that you don't want to be visible in the 3D view, you will have to hide those levels - Ctrl+Shift+H is the shortcut for that I think.
[Jun 14, 2024, 3:59:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
