中国
Windows 11 - not possible to save/save-as !!!!!
I installed 7.2 it would't save or save as any new project,Java was smoothly. And i try lot of steps the same of http://www.sweethome3d.com/support/forum/viewthread_thread,11932 but finall would't save or save as....
[Edit 1 times,
last edit by Puybaret at Jan 18, 2024, 8:49:15 AM]
中国
Re: Windows 11 - not possible to save/save-as !!!!!
It not able save or save as when i want to have a new project it nothing happened as "I try to open a file ("open" dialogue) nothing happens. Same when I try to save or save-as, nothing happens. When I try to close the application it asks me if I wanted to safe the progress - when I click save nothing happens, no window pops up for me to choose the destination....." from anothers case of forum.
Maybe try to run the program as administrator. Even if it’s not the best solution, you could also start from an empty file that you would open with a double click then just choose the Save menu item. Just use the EmptyFile.sh3d attached to this post and rename it if you want.
---------------------------------------- EmptyFile.sh3d
(3279 bytes)
(Download count: 1422)
(Empty home file)
中国
Yes,I do and able to save but wouldn't save as...what's happening...please help to solve it. Need to change Windows version or not? I try to run with administrator but the same...wouldn't save or save as.
Run the program from a terminal window Only logs might help me understand what’s going on.
