Print at Aug 21, 2026, 8:58:56 AM
Posted by Devm at Jan 18, 2024, 4:45:15 AM
Windows 11 - not possible to save/save-as !!!!!
I installed 7.2 it would't save or save as any new project,Java was smoothly. And i try lot of steps the same of http://www.sweethome3d.com/support/forum/viewthread_thread,11932 but finall would't save or save as....
Posted by Puybaret at Jan 18, 2024, 8:52:17 AM
Re: Windows 11 - not possible to save/save-as !!!!!
What do you mean by it "wouldn’t save"?
Posted by Devm at Jan 18, 2024, 11:31:58 AM
It not able save or save as when i want to have a new project it nothing happened as "I try to open a file ("open" dialogue) nothing happens. Same when I try to save or save-as, nothing happens. When I try to close the application it asks me if I wanted to safe the progress - when I click save nothing happens, no window pops up for me to choose the destination....." from anothers case of forum.
Posted by Devm at Jan 18, 2024, 11:36:33 AM
Thanks for your support & helf...better to have any ID of online chat then easy to show what appened now.
Posted by Puybaret at Jan 18, 2024, 12:13:49 PM
Maybe try to run the program as administrator.
Even if it’s not the best solution, you could also start from an empty file that you would open with a double click then just choose the Save menu item. Just use the EmptyFile.sh3d attached to this post and rename it if you want.
Attachment EmptyFile.sh3d (3279 bytes) (Download count: 1422) (Empty home file)
Posted by Devm at Jan 18, 2024, 2:30:29 PM
Yes,I do and able to save but wouldn't save as...what's happening...please help to solve it. Need to change Windows version or not?
I try to run with administrator but the same...wouldn't save or save as.
Posted by Puybaret at Jan 18, 2024, 2:52:34 PM
Run the program from a terminal window
Only logs might help me understand what’s going on.
Posted by Devm at Jan 19, 2024, 2:59:22 AM
I have do it but nothing happened and did't get log.
Posted by Devm at Jan 19, 2024, 6:24:50 AM
Any other options to solve this problem?
Posted by Puybaret at Jan 22, 2024, 11:19:57 AM
See bug #1212
