Total posts in this thread: 4
Previous Thread This topic has been viewed 1283 times and has 3 replies Next Thread
jllh76
Alignment
Hello,
I'm using SH3D 7.2 and noticed the following :
Depending on the objects, some can stick completely to a wall (e.g. an electrical outlet) and others with magnetism activated remain approximately 1mm from the wall.
Is it possible to change a setting to stick the furniture completely to the walls?
Thanks in advance
[Nov 19, 2023, 7:36:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Alignment
Zoom in to see and move with greater accuracy. Fully zoomed in you can move 1mm with the cursor. Zooming out that movement is bigger and depends on how far you zoomed out.
You probably stuck the object to the wall when zoomed out and that can cause the remainder of the 1mm gap when it's calculated with step sizes > 1mm.
[Nov 19, 2023, 8:15:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Alignment
It may be also because you add baseboard on your wall...
[Nov 19, 2023, 9:33:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jllh76
Re: Alignment
Hello VeroniQ,
Thank you very much!
You have found my problem, it is since I added the plinths, because with the zoom in fully it did not want to stick to the wall, I had to "play" with a socket to make an alignment to correctly position my object.
Thanks to you two
[Nov 19, 2023, 10:04:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
