Total posts in this thread: 6
Previous Thread This topic has been viewed 4912 times and has 5 replies Next Thread
MurphyHasBeen
Tiny labels
Hello! I am new to this program, and it seems like just what I was looking for. I have a problem, though: The two windows at left, pertaining to furniture import, have labels nearly too tiny to see. This appears to have been a problem in the past but was said to be resolved in version 6, but I have the latest version, 11.0.18. Is it possible to correct this? I'm running Windows 10 Home Build 19045. Thanks!
[Sep 2, 2023, 12:27:12 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Tiny labels
The most recent version is 7.1 (or the beta version 7.2.beta7).
If you have a HiDPI screen upgrading to 7.1. should solve the problem. (I think that was fixed in 6.5.)
You can see your current version when you click the menu item Help>About.
[Sep 2, 2023, 10:52:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MurphyHasBeen
Re: Tiny labels
Thank you for your reply. I have version 7.1.1 and am experiencing this problem, so it hasn't been solved. I'd like to try the beta, though; can you tell me where to find it? It is not on the Download page.
[Sep 2, 2023, 5:13:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MurphyHasBeen
Re: Tiny labels
I found via this page that I had "custom scaling" enabled in Windows and have turned that off. However, doing so did not fix my problem in Sweet Home 3D.
https://www.digitaltrends.com/computing/how-t...pi-scaling-in-windows-10/
[Sep 2, 2023, 5:35:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Tiny labels
The 64 bit version of Sweet Home 3D handles this issue better.
Can you check in About dialog box if you installed the 32 bit or 64 bit version?
To install the 64 bit version, run the installer again and select 64 bit architecture when prompted.
[Sep 2, 2023, 6:22:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MurphyHasBeen
Re: Tiny labels
I had the 32-bit version installed but upgraded to 64 bits, and the problem persisted. I then tried uninstalling and installing again -- no luck. (I'm using the paid-for version, if that's helpful.)
[Sep 2, 2023, 8:33:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
