Previous Thread This topic has been viewed 377696 times and has 90 replies Next Thread
Re: Sweet Home 3D 7.2
If it’s just an issue with Save as menu item, it’s certainly another issue, maybe a permission issue in Windows. If you can still save with Save menu item, I would simply rename the file in Windows Explorer before saving the project. This will have the same effect as Save as menu item.
[Feb 21, 2024, 9:34:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
That's what I've been doing. It's just a major annoyance. Also the furniture import doesn't work either and when I do a 3D render I can't save the image. I have to make a screenshot of the preview window resized instead which probably isn't the better quality image. No other app on my Windows 11 Pro computer has such issues. This didn't happen on my Windows 10 computer from a year ago but I no longer have that system. Could be any of the Windows Updates during the year too. I used the regular Windows installer for SH3D and don't have Java installed. When I tried to reinstall before with the Java Web Start version SH3D keep trying to launching incorrectly in a web browser, I think. I have to go back and review my old forum posts when I complained about my issue before for the exact symptoms. Not sure what can be done on my end. I love this program and would hate to resort to learning a different app instead. I'd probably give it up and build cardboard models instead LOL.
[Feb 21, 2024, 10:25:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Another thing is I have tons of dimensions in my floor plans. Is that a bad thing?
[Feb 21, 2024, 11:25:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you try the suggestions in the FAQ Sweet Home 3D refuses to save a file I created. How can I fix this issue?
By the way, can’t you import a 3D model by dragging its file from Windows explorer onto the plan in Sweet Home 3D window?
[Feb 22, 2024, 12:27:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Yes I tried that with various memory settings, no effect on my issue. I tried it with and without the latest Java installed. Like I said I'm not running the Java Web Start version so don't know if that is required to use the .ini file. The drag and drop method works for the import stuff. Just makes it awkward and counter-intuitive.
[Feb 22, 2024, 4:28:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Also Controlled Folder Access is set to OFF.
[Feb 22, 2024, 4:32:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Are you able to save a new home?
[Feb 22, 2024, 8:47:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I can do a regular file/save of my home from within SH3D, but can't do a file/save-as nor able to save a 3D rendering from the save button. The button does nothing. Obviously it's not folder permissions if I can do a regular save there and copy files there.
[Feb 22, 2024, 11:03:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
But are you able to create a brand new home then save it?
[Feb 23, 2024, 12:01:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I just created a 12'x12' room with walls and attempted to save it. Nothing happened. When I exit SH3D it asks, do you want to save home? I click save the dialog box goes away. I then go to exit SH3D and it keeps asking me to save it or changes will be lost. The only way I can exit is to click on cancel or do not save and then exit. Yet on my large home model I can open it and it does at least let me "save" changes but not do a save-as so I can give it a new name without overwriting the old one. Strange... I don't know if there is something within my Windows 11 Pro installation blocking SH3D features but this is the only program to have any sort of problem. Here is a list of all installed programs on my PC:
Name & Version
Intel(R) Wireless Bluetooth(R) 22.230.0.2
AMD WVR64 1.0.2
Intel(R) Management Engine Components 1.0.0.0
AMD Radeon USB LED Application 1.0.1
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 10.0.40219
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 10.0.40219
Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.21005 12.0.21005
Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.21005 12.0.21005
AMD Settings 2024.0111.1250.2016
Microsoft Visual C++ 2022 X64 Additional Runtime - 14.36.32532 14.36.32532
Apple Software Update 2.7.0.3
iTunes 12.13.0.9
LibreOffice 24.2.0.3 24.2.0.3
ENE_X_AIC_HAL 1.0.6.3
AMD DVR64 1.0.2
WD_BLACK AN1500 1.0.12.0
Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.21005 12.0.21005
WD_BLACK D50 1.0.9.0
Verbatim_SureFireGaming_Product 1.0.3.11
Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.21005 12.0.21005
Dynamic Application Loader Host Interface Service 1.0.0.0
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030 11.0.61030
Documentation Manager 22.180.0.4
Ableton Push Driver v5.50.0 5.50.0
Intel(R) Icls 1.0.0.0
Bonjour 3.1.0.1
Apple Mobile Device Support 17.0.0.21
Intel(R) ME WMI Provider 1.0.0.0
Intel(R) Chipset Device Software 10.1.19376.8374
ENE_MousePad_HAL 1.0.2.0
4K Video Downloader 4.24.4.5430
Microsoft Visual C++ 2022 X86 Additional Runtime - 14.36.32532 14.36.32532
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 11.0.61030
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030 11.0.61030
ENE Video Capture Box HAL 1.0.5.15
Intel(R) Management Engine Driver 1.0.0.0
Ableton Live 11 Lite 11.0.0.0
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 11.0.61030
Microsoft Update Health Tools 5.72.0.0
Microsoft Visual C++ 2022 X86 Minimum Runtime - 14.36.32532 14.36.32532
WD P40 Game Drive 1.0.2.18
Branding64 1.00.0009
ENE_External_Device_HAL 1.0.11.1
Microsoft Visual C++ 2022 X64 Minimum Runtime - 14.36.32532 14.36.32532
ENE_EHD_M2_HAL 1.0.12.2
AMD User Experience Program Installer 2340.0.0.111
[Feb 23, 2024, 6:02:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
