Previous Thread This topic has been viewed 377672 times and has 90 replies Next Thread
vl4d
Re: Sweet Home 3D 7.2
Yes I do use levels at the same elevation.
It is very minor issue, i do export it to csv and work with that, but for me verifying if I have all items i need to order (pipes, fittings, valves, ...) it is easier to just go trough the "level" and list of items directly in the sweet home 3d as it highlights me what the items in on the plan.
[Oct 30, 2023, 11:54:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I corrected the order issue in the furniture list and the correction will be available in the next version. Levels in the list will be sorted in the same order as level tabs for consistency.
[Nov 6, 2023, 12:50:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Great! Thank you.
[Nov 6, 2023, 1:48:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
I have the newest 7.2 installed and even did a clean install. Just curious if SH3D has memory usage limits and/or file size limits? Still get that issue where I can load a large complex 233mb fie but can't do save-as or normal furniture file import without using drag and drop instead. I know building my home 3D model is not optimized like a pro (had someone here look at it) but the save-as not working (ignores me clicking on the menu option) is my big issue. Maybe if I combine multiple custom structures like stair steps into single models might help or do i have to dumb down the detail? My PC has 32gb RAM and an i7- 12700kf 3.6ghz CPU and AMD Radeon RX 6950 XT GPU and NVMe SSD drives. Maybe something to ponder for a future 7.3 version...
[Feb 21, 2024, 12:05:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Yes, there is a configurable limit for the memory usage. Search for "How can I adjust the memory used by Sweet Home 3D?" in the FAQ.
[Feb 21, 2024, 7:19:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
By default, Sweet Home 3D 64 bit is configured to use up to 50% of free RAM under Windows so I'm not sure it's a memory problem. Could you report what information memory information is displayed in About dialog box, in the line indicating the Java used version?
[Feb 21, 2024, 11:29:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Sweet Home 3D ® Version 7.2
OpenJDK version 11.0.18 - 64bit - 0.1 / 11.9 GB provided by Azul Systems, Inc. Java 3D version 1.6.2a - JOGL 2.5.0 provided by JogAmp Community PDF print provided by iText SVG export provided by FreeHEP SVG path compilation provided by Batik Photo rendering provided by SunFlow and YafaRay
Please, visit http://www.sweethome3d.com/ for software updates and bug report.
© Copyright 2006-2023 eTeks <[email protected]> Distributed under GNU General Public License
[Feb 21, 2024, 3:00:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Also I'm not using the Java Web Start version.
[Feb 21, 2024, 3:12:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It could be a special 3D model you imported, maybe a large one but not necessarily the largest one.
Display the Model size column, sort the furniture list on this criterion and hide the largest ones until your 3D view runs normally, then make them visible one by one and check which one slows down the 3D view.
But it could be also the number of objects in your project.
[Feb 21, 2024, 6:32:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snmavronis
Okay I'll try hiding the largest models and test for that. I could see if it slowed down the 3D view but mine runs pretty fast. But not sure how that would make the save-as option not work. I can do a regular save and save compressed. I'll let you know when I get a chance to do some testing as you suggest. Thanks.
[Feb 21, 2024, 8:26:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
