Posts: 16   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 6113 times and has 15 replies Next Thread
Daniels118
Italy
Re: Object surfaces reflect environment?
Have you tried this?
Also remember that you can change the shininess of materials from the furniture modification dialog, and export the object to check what changes in the mtl file.
[Jul 3, 2023, 5:16:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
selden
usa
For some reason I thought one could not export one of the "in use" objects.... Unfortunately, I can't find that option (to export a furniture object)
*sigh* must be another item that's right in front of me.
Selden
[Jul 3, 2023, 7:41:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
selden
usa
There's an "export to csv" but that just exports the list of in-use objects... and it's actually an "export to TAB separated values", not "Comma separated values"
Selden
[Jul 3, 2023, 7:45:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
The export command is in the 3D view menu. You have to select the object to export first. You may also use this function to merge 2 or more objects.
[Jul 3, 2023, 8:26:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
selden
usa
Oh. Of course. I've even used it a kajillion times. *sigh*
Anyhoo...
I did a save-to-obj for the object both when it was reflective and when it wasn't. The only difference between the matt .mtl and the reflective .mtl is the Ns value.
Reflective:
newmtl brown
illum 2
Ka 0.2 0.2 0.2
Kd 0.533 0.4 0.267
Ks 0.0 0.0 0.0
Ns 128.0
NON-reflective:
newmtl brown
illum 2
Ka 0.2 0.2 0.2
Kd 0.533 0.4 0.267
Ks 0.0 0.0 0.0
Ns 1.0
Selden
[Jul 3, 2023, 11:26:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
selden
usa
Fortunately, it turns out that an NS of 0.0 works just as well as 1.0
I've been using Anim8or to create my obj models. Ns seems to be controlled by a combination of Anim8or's material values of "Rough" and "Brilliance". Setting them both to 1 yields an Ns of 0.0
Selden
[Jul 4, 2023, 12:04:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
