Belgium
Starting SWH3D 7.1 on Linux Mint
Installed afresh SWH3D 7.1 on fresh Linux Mint 21.1. 1- when starting the app Linux mint says "Do you want to run SWH3D or display its content ?¨ Options "Run in terminal" "Display" "Cancel" "Run" File propererties rw-r -r -x
Romania
Re: Starting SWH3D 7.1 on Linux Mint
Is all of this necessary, is there a simpler way ?
Ask the guys who make the snap package for Mint. If You read and follow the official linux install instructions from here and the few recommended links, you could have something like this (mine) as desktop shortcut:
[Desktop Entry] Comment[en_US]= Comment= Exec=/home/nea-dorin/Sweet_Home_3D/SweetHome3D-7.1/SweetHome3D-nimbus GenericName[en_US]=Home designer GenericName=Home designer Icon=/home/nea-dorin/Sweet_Home_3D/SweetHome3DIcon.png MimeType= Name[en_US]=Sweet Home 3D Name=Sweet Home 3D Path=/home/nea-dorin/Sweet_Home_3D StartupNotify=true Terminal=false TerminalOptions= Type=Application X-DBUS-ServiceName= X-DBUS-StartupType= X-KDE-SubstituteUID=false X-KDE-Username=
In this way you will avoid many other headaches.
Belgium
Ask the guys who make the snap package for Mint. If You read and follow the official linux install instructions from here and the few recommended links, In this way you will avoid many other headaches.
Dorin, [moderated] a) Mint doesn´t use SNAP, SNAP was the reason why I quit Ubuntu for Linux Mint in the first place, SNAP is turned off in Linux mint, so there is no SNAP specialist at Linux Mint to ask silly questions b) I installed the SWH3D from the sweethome3d.com/ repositories according to the instructions on the website c) unless i missed something I did perform the actions necessary to create the desktop file That transcient desktop file is actually created when SWH#D is started, then I copied and saved it into a desktop file .
I will try if your desktop file works ...
[Edit 1 times,
last edit by Puybaret at May 25, 2023, 6:22:46 PM]
Romania
I'm sorry! The content of your desktop file suggested me the SNAP or other kind of installation.
Few unnecessary indications: After you extract the SweetHome3D-7.1-linux-x64.tgz, inside the folder SweetHome3D-7.1 you will have two bash files: SweetHome3D and SweetHome3D-Java3D-1_5_2. To one of this have to point the Exec= statement from desktop file. All your huge entry it is inside of this files and this is necessary for program to run. My SweetHome3D-nimbus it is a customized file to use Nimbus Look and Fill. Also, in my installation, I use an extra folder, to store multiple variants of SH3D and the editors, named Sweet_Home_3D.
