Total posts in this thread: 5
Previous Thread This topic has been viewed 12684 times and has 4 replies Next Thread
thomasmendozajr
United States
Is there away to change 2D background color?
I was wondering if there was a way to change the background color in the 2d window Od rather use a darker color
[Jan 21, 2023, 6:54:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Is there away to change 2D background color?
Only by program, by calling setBackground method on the plan component.
[Jan 21, 2023, 11:35:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
You may import a background image of the color you like. When importing specify a size larger than your home so that it covers the whole plan even if you zoom out.
You have to import the background on each level.
Be aware that a too dark background will reduce the contrast with lines.
[Jan 21, 2023, 11:40:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
thomasmendozajr
United States
Sounds good but how do I call setbackground on plan component? I haven’t messed with a lot of coding in sweethome3d but that would be great so I can set plans for all my foundations plans and layout plans,
[Jan 21, 2023, 3:14:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If you're able to run Sweet Home 3D from code source, simply change implementation of getBackgroundColor and getForegroundColor in PlanComponent class. Otherwise, this might be difficult.
[Jan 21, 2023, 6:59:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
