Total posts in this thread: 5
Previous Thread This topic has been viewed 13125 times and has 4 replies Next Thread
Lysakowski
United States
shock errors importing or installing plugins
I get the same error message when trying to import .sh3p files, error importing or installing plugin:
"Can't import plug-in
"c:\users\poweruser\desktop\home_renovation\sweethome3d\models-various\evidencemarkergenerator-1.1.sh3p"
I am running SweetHome 3D version 7.0.2 on Windows 10 Professional.
I have tried with the following plugin files:
StaircaseGenerator-1.0.sh3p
GenerateRoof.sh3p
ExportPlanImage-1.0.sh3p
and others.
Do the files need to be in a specific directory? I am importing them from my working directory.
.sh3p files are supposed to be native SH3d files aren't they?
I try double-clicking on the .sh3p files and still get the message above.
If I use the menu "Furniture... Import... " and then either select a file or drag-and-drop a file. I get errors with .sh3p, .zip, and .obj files.
I am new to SH3D, so this is frustrating my effort to get my construction renovation project done.
[Edit 2 times, last edit by Puybaret at Jan 9, 2023, 5:14:49 PM]
[Jan 9, 2023, 10:21:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: errors importing or installing plugins
You probably haven't the right to write in the folder where plug-ins are stored.
Can you try to place these plug-ins in the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\plugins (where user is your login) and restart Sweet Home 3D?
What do you mean by "native"?
Import menus are not used to install plug-ins.
[Jan 9, 2023, 5:21:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lysakowski
United States
I installed with full administrator privileges.
There is no folder named:
"C:\Users\<<user>>\AppData\Roaming\eTeks\Sweet Home 3D\plugins"
I found these eTeks related folders:
"C:\Users\PowerUser\eTeks" (EMPTY)
"C:\Users\PowerUser\eTeks\Sweet Home 3D\recovery" (EMPTY)
All the subfolders in this parent folder are EMPTY:
"C:\Users\PowerUser\AppData\Local\Packages\eTeks.SweetHome3D_y7v7etvrysvmm"
"C:\Users\PowerUser\AppData\Local\Packages\eTeks.SweetHome3D_y7v7etvrysvmm\AppData"
I first did a portable installation of the free version (from SourceForge), and then I installed the version from the Microsoft Store, and I cannot (yet) find where the Microsoft Store version is installed. I hate using the Windows Store because it hides things away from users.
After the Microsoft Store installer, I am still not able to install the plugins, because I cannot find the plugin directory.
By the way, "native" format means the file format(s) that are native to an application, e.g., sh3d for SweetHome 3D, xlsx for MS-Excel, docx and doc for MS-Word. These are also the file extensions that get registered by the Windows operating system in the Windows Registry.
Is there a way to download the "Pro" (paid) version and install it manually without using the Windows Store?
[Jan 9, 2023, 11:34:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Create it yourself and place some .sh3p files in it.
[Jan 12, 2023, 10:00:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
saitama_hadumsky
россия
hi, I have almost the same problem, but I don't get an error message, and the plugins just don't work, I click on tools, click on the plugin and it doesn't work
[Dec 8, 2023, 1:10:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
