Total posts in this thread: 4
Previous Thread This topic has been viewed 2454 times and has 3 replies Next Thread
crackwood01
Canada
confused Unable to render
i can't render my project.
I don't know if it is a particuler object thats create a bug.
I've always been able to use yafaray or another motor.
Nohing happens at all, just a grey screen.
http://www.crflix.ca/docs/Projection.sh3d
Merci!!
[Oct 17, 2022, 4:12:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Unable to render
I just tried your file and had no problem.
Did you succeed to render that particular project? Did you relaunch Sweet Home 3D?
[Oct 17, 2022, 6:16:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
crackwood01
Canada
i can render other projects but not this one
[Oct 25, 2022, 11:38:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
You have a 3D dimension line hidden behind the shower. Please note that the versions of 3D dimension lines plugin prior to 3.1 break the rendering (if a 3D dimension line is in the scene). Please check if you have the latest version of the plugin. I recommend to use the Plugin manager with "check for updates" option enabled to keep all plugins updated.
[Oct 26, 2022, 5:29:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
